rear end change Morning guys.....while going through the rear brake's on the roadster. I discovered that the linings were completely gone....the grease seals are leaking and everything should be completely disassembled and cleaned and rebuilt.. My question is....I have another rear end that I bought from a reputable guy that has been rebuilt and has new brakes on it.the radius rods are on it and the have been blasted and powder coated.....would it be easier to change the rear end rather than disassembling the old one and replacing the brakes? I will also add that the drive shaft and torgue tube are still attached to the new rear end and that I would most likely use those as well. Can I install the rearend and dirive shaft as on unit.
Thanks e everyone. |
Re: rear end change Yes you can install as a unit. You will need a spring spreader as the rear spring is under tension and can be dangerous.You can take spring out with the axle assembly or leave it on the car. Roll the old axle out on a floor jack and roll the new one in.
John |
Re: rear end change R&R the complete rear end is much quicker and easier than rebuilding what you have.
Re: rear end change thanks guys...I thought that was going to be the answer. Where do I get the spreader...is it something I fabricate or buy from a vender?
Re: rear end change 1 Attachment(s)
I bought this one on eBay:
Re: rear end change The vendors sell a quality spreader.
Re: rear end change If you have a local Model A club, they may have one in their "tool chest".
Re: rear end change Fred....I wish I had a club near me.
Re: rear end change Check the rear end ratio on the new rear end before you install it and be sure it is something you will like.
Charlie Stephens |
Re: rear end change Thanks charlie.
Re: rear end change Just got off the phone with Don at Snyders.....ordered a new spreader. Better have the right tool for the job.
Re: rear end change Quote:
Re: rear end change include pics for usn's that are going to do the same job,when/if it warms up...thanks kev
Re: rear end change I will Kevin....I just got an email and the spring spreader is backordered a week or two. I'll post pics when we do the job. I'd be willing to loan the spreader when I'm done with it.
Re: rear end change Hello guys, working on my 32 Pickup, removed rear end, replaced the shackle bushings, now ready to install rear end. I put shackles plates on passenger side rolled over to the drive side, and have a 3-4 inch between spring eye and housing? Is this where the Leaf Spring Spreader comes in handy?
Frank |
