KR Wilson Line Bore Frame 1 Attachment(s)
The KRW Model A Line Bore frame I purchased has had the Babbitt removed. It is still straight and true and no signs of heating.
Anyone have experience replacing the bearings in one? Maybe just another piece of wall art? |
Re: KR Wilson Line Bore Frame What is jigging putty? Does it get hard, or stay somewhat soft? What color is it? I assume it's good for high temps?
I'm trying to figure if it might be used for the distributor plug. |
Re: KR Wilson Line Bore Frame Thanks Ray, maybe mix a little lamp black in and it might be good for the distributor plug.
Re: KR Wilson Line Bore Frame Tom, Do you mean the little plug that one places over the condenser fastener screw hole? It was some kind of a tar or resin looking black dollop of hardened goo in the original form. Nobody seems to know except approximately what it looked like. Let me know if that's what you mean because "Fred" and I have worked something out for it. Rancho
Re: KR Wilson Line Bore Frame |
Re: KR Wilson Line Bore Frame Rancho, yes, that's what I mean. A friend of mine has the original plug still in his distributor.
I wonder if the Benson Ford Research Library has any details about the plug? |
Re: KR Wilson Line Bore Frame Quote:
Re: KR Wilson Line Bore Frame 2 Attachment(s)
This is how Bill Barlow solved this. He uses a boring bar with removable cutters.
Re: KR Wilson Line Bore Frame James,
That sounds like the most reasonable solution. I need to machine the bushings to fit the frame. What I'm hearing is that the bores in the frame are precision machined. I was wondering how I was to center new bearings in the frame if they were not..... |
