The Ford Barn
-   -   Rotella 15-40 oil? (https://www.fordbarn.com/forum/showthread.php?t=161912)
FrankWest 02-20-2015 01:59 PM
Rotella 15-40 oil?
Does anyone use this oil in their model A or Model B engines?
I seem to remember an article or somewhere " maybe in a dream or nightmare" that some model A owners use this "diesel engine" oil???
jaysberman 02-20-2015 02:02 PM
Re: Rotella 15-40 oil?
Have been using them in the v-8's for years and have many thousand miles on them.
This will probably start a hornets nest.
zzlegend 02-20-2015 02:06 PM
I use it in my A and my 2 flatheads.
31 Model A 02-20-2015 02:22 PM
I bath in the stuff, it's that good!!!!:D
Patrick L. 02-20-2015 02:24 PM
It works just fine, even though I'm not supposed to respond. I use it so you may not want to.
Dtolson 02-20-2015 02:26 PM
I use in my 29 CCPU. Great product.
Mike V. Florida 02-20-2015 02:26 PM
It will work as will any oil rated for motor vehicles. The "diesel" oil has more zinc in it. It is said that the zinc in needed in our engines. It is also said it is not needed.
Any guesses on how many pages the this which oil to use thread will go on? I say 4.
mshmodela 02-20-2015 02:31 PM
It's a popular choice with folks here and at least my Model A club.. I think the grade of oil is the most important thing as all modern oils are much better than what was used in the past. I'm running it now. I plan on tossing my oil for the spring just incase any extra moisture accelerated in the motor over winter (it has just a few miles on it..) Oil is cheap...
marc hildebrant 02-20-2015 02:46 PM
Currently in my Model A. First heard about it on the barn via Purdy S.
Marc
CarlG 02-20-2015 02:59 PM
I'm thinking about it after I get my engine back together. Wish I could find it reasonably priced in quart bottles instead of gallons.
Mitch//pa 02-20-2015 03:01 PM
Yes
Big hammer 02-20-2015 03:34 PM
At work they use Rotella in everything! I saw timing chain area open and OMG the junk, of course many hours if idle time, and oil changes on time?
FrankWest 02-20-2015 03:35 PM
WOW! I had no idea. Thanks
JD Miller 02-20-2015 03:38 PM
I've been using Rotella 15-40 for several years with good results. The diesel oil has the additives that are supposed to help lubricate/protect our older type engines.
1938 Woody Cape Cod 02-20-2015 04:36 PM
I use it in all my engines...........Bob
hardtimes 02-20-2015 04:39 PM
X-2 !!
BTW, you can call it 'diesel engine' oil and/or whatever, but by any other name, it is just right for a warmed up B or worn out A engine :)
Jeff/Illinois 02-20-2015 06:25 PM
And this was using Rotella:confused::confused::eek:
Dusty 02-20-2015 08:14 PM
I it use exclusively but good Lord I have green fenders and white walls:rolleyes:
Bruce Adams 02-20-2015 10:49 PM
Rotella initially started making inroads into the Model A hobby because as a "Diesel" oil it did not have to meet SAE level M low-levels of zinc which, in my opinion, has kept our engines running for 85 years because of its higher levels of ZDDP, zinc lube which was removed due to newer catalytic converters in newest cars.
It took off from that with the enthusiasts who care most for their cars.
CWPASADENA 02-20-2015 11:02 PM
Rotella is very good oil.
Zinc in a model A is not as critical as later OHV engines with flat tappet cam followers and higher valve spring rates and more aggressive cam profiles. Zinc is necessary to keep the cam lobes from scuffing. While zinc may not be necessary in a Model A with stock valve train, it certainly will not hurt anything.
I run oil with zinc in all my old cars.
Just my opinion.
Chris W.
