motor mount part #? Anyone have a part # from Van Pelts, Macs etc for the rear motor mounts on a '35 V8 pickup?
Looking for the rear rubber mounts and harware only. Have a new trans mount and new front mounts that came in the basket of parts with truck. Thanks, Chris |
Re: motor mount part #? What rear mounts are you referring to? There are engine mounts (at the front of the engine) and a transmission mount (rear of the transmission).
Re: motor mount part #? Sorry I think I have the answer. The trans mount ears bolt directly to the frame. No rubber there.. Hard with the frame in one shop and the motor and trans in a shop across town and this being the first one that I have tackled.
Thanks though, Chris |
Re: motor mount part #? Yep, think you have it.
Re: motor mount part #? NO you don't have it. use the same donut.( bisquits ) at all four points, complete set, top and bottom, you bolt the rear trans mount down solid to the frame, it will break, think about it, you got rubber at the front and solid at the back something going to give, and you will be looking for a new rear trans mount ?? ............OLD.......BILL
Re: motor mount part #? Quote:
The cushion is in the mount itself. |
Re: motor mount part #? Thanks,
I thought there should donuts at the rear also until I realized that the rubber cusion is it the trans mount. Richard Lacy confirmed there was no donuts on back. |
Re: motor mount part #? And that rubber ring can be replaced if petrified.
