water flow direction for heater 1953 ford on a 1953 Ford passenger car, in what direction does water flow for the heater?
from the head thru the heater core to the water pump OR from the water pump thru the heater core to the head? |
Re: water flow direction for heater 1953 ford The latar I believe
Re: water flow direction for heater 1953 ford Just make sure that your hot water enters the BOTTOM of the heater. That way, the heater is always full of hot water. If it enters the top, it can just fall through and cause air pockets.
MIKE :) (mikeburch) |
Re: water flow direction for heater 1953 ford Quote:
From the head to the bottom of the core and out the top to the water pump. Bill |
Re: water flow direction for heater 1953 ford My father drilled this in me 60 yrs ago "top to bottom and bottom to top"
easy to remember |
