Advice on engine/transmission removal Would you suggest removing the engine/ transmission as a unit, or separate them? Thank you in advance.
Re: Advice on engine/transmission removal I took it out together
Re: Advice on engine/transmission removal for me it depends on what is getting done
Re: Advice on engine/transmission removal I am replacing the engine and rebuilding the transmission, so they will be getting split anyway. Just wondered as to what was suggested.
Re: Advice on engine/transmission removal my preference would then be as a unit
Re: Advice on engine/transmission removal shove a lifting eye in hole #3 and you have perfect balance and can haul them right out as a unit
this is how the old timers did it. and how we do it |
Re: Advice on engine/transmission removal Thank you. That is what I will do.
