Any body using EZ Steering box Just curious as to how the EZ box works in the car and the price. Had a Vicky with the F-100 box and it was like power steering.
Re: Any body using EZ Steering box Do a search.
The EZ box is a POS. The F-100 box is great. |
Re: Any body using EZ Steering box 1 Attachment(s)
Re: Any body using EZ Steering box Over on the HAMB ,A lot of talk on it, from what I have read ,
no one like's it , not easy to install , and the guy who sell it , they do not care for him!!!!! |
Re: Any body using EZ Steering box I need to check and see if I am correct on E Z steering , I do not wante to post incorrectly ,
I should have check before I posted !!!! I am Correct , it is E Z steer , That they are talking about on the HAMB |
Re: Any body using EZ Steering box Carl has it right. Old post from the hamb. Good luck.
http://www.jalopyjournal.com/forum/t.../#post-6610083 |
Re: Any body using EZ Steering box EZ junk!
Re: Any body using EZ Steering box When I purchased my A,it would not return to neutral with out armstrong it back.
I removed column cleaned inside box new gaskets adjusted by service bulletins! It would then spin back to neutral on more slop in the wheel work great! This was done by a 17 yr old with out the Barn just followed Fords Service Bulletin book!!! |
