radiator sides and top paint? Ford a 1933 model B was this flat black or semigloss black?? Will rustoleum work in this application? Heat?
Re: radiator sides and top paint? I use BBQ grill paint. Takes heat and sheen is just right.
Re: radiator sides and top paint? Quote:
Re: radiator sides and top paint? It won't hurt to give the fins a bit of a squirt but don't overdo it as you want to cool that engine.
GB |
Rustoeum high temp is a flat black that is almost gray. |
Re: radiator sides and top paint? There is a Radiator black that has adhesion properties in it ,about 50% gloss .Not sure were you would get it on your side of the pond
Re: radiator sides and top paint? Its called Radiator black .Ted
Re: radiator sides and top paint? 1 Attachment(s)
Eastwood Radiator Black Paint Satin Finish Aerosol 12oz |
Re: radiator sides and top paint? Another option would be to take your radiator to a radiator repair shop and have them paint the fins. If they want to charge very much you have gone to the wrong shop.
Charlie Stephens |
