1939 Ford Standard Headlamp Buckets I am installing LED headlamps in my 39 Ford 2dr sedan standard and the headlamps are the correct diameter but because the LED has a back plastic housing for cooling purposes the headlamps in the standard factory bucket are tight against the sides and give me zero adjustment. Anyone done this and have ideas. I am thinking about adding a section to the bucket to make it longer but really need some more diameter to allow for headlamp movement/adjustment. This is my weekend project so all wild ideas will be appreciated.:confused::confused:
Re: 1939 Ford Standard Headlamp Buckets Hey guys...... I really need some ideas on this as I am still struggling on what to do. Surely there is some wild idea out there to help me!!!!
Re: 1939 Ford Standard Headlamp Buckets It does sound like you will have to make the bucket bigger.
Or just not use them. Mart. |
Re: 1939 Ford Standard Headlamp Buckets Chief, I doubt that you'll ever get LEDs adjusted to work with the '39 Standard lens, no matter what you do with the reflector.
