'32 front radius rod cap Does anyone have a picture of a '32 wishbone cap (where the ball is)? I have one but not sure if it is correct. Put on a new rubber ball and there is still some slop when the cap is bolted down tight. Should there be play in this?
Re: '32 front radius rod cap the reproduction wishbone rubber ball is sized wrong.
Re: '32 front radius rod cap Not sure where I saw this but there are shims made to go inside the rubber ball to make up for wear, might have seen these in Mac's. Pete
Re: '32 front radius rod cap I found this shim at Mac'sPart # 47-22441-1, hope this helps. Pete
