33/34 rumble panel install 2 Attachment(s)
In the space between the triangular piece and the rear quarter flange (see pix red arrow) ...are there a spacers in OEM to match the space created by the U shaped rain gutter (see pix blue arrow).
Does anyone know other source for the panel with the half round (see other pix) other than Howells or Steve's real steel. I do not think I can find a good OEM one and I have shape issues with the repo Thanks Ed Solari |
Re: 33/34 rumble panel install 2 Attachment(s)
Another source (the one I use) is:
R&J Enterprises 6034 302nd Rd, Arkansas City, KS 67005 (620) 441-0032 Can't comment on shape verses Howells or Steve's, R & J fab most of their own panels, but are also a supplier for a lot of the other sources, so? You are aware that there are several other parts that go into this area? Not sure what you are calling a spacer. |
Hey Ed , Your first pic is right other than the stops and dam are not there . Other post is a trunk setup and is not the same . No clue on a better inner panel and used ones in good shape are RARE to say the least . Pics are 33's but are the same as 34 . Dave
Re: 33/34 rumble panel install Thanks David, I read the post and not the title!
Re: 33/34 rumble panel install Ed I think the lower part of 1/4 flange has a kink in it to compensate for the gap in the three layers .
Re: 33/34 rumble panel install Question ended up being about the layering order of components down below the deck opening . The reinforcement for the bolts and edge goes between the quarter lip and the triangle piece . The gutter goes between the quarter lip and triangle piece also so if properly assembled there is no step or gap . I answered the wrong question myself to start with . :o
