The Ford Barn
-   -   transmission (https://www.fordbarn.com/forum/showthread.php?t=156228)
FRANK PKNY 12-03-2014 10:43 PM
transmission
Any0ne have experience in putting a 39 transmission in a model A ? I have two rebuilt 39 top loaders and have been contemplating on putting one in my Model A wondering if there is some input out there?
Chuck Sea/Tac 12-03-2014 11:45 PM
Re: transmission
Have you searched the archives? It's been discussed several times, including just recently.
I don't know how to que it.
I can't seem to find it, but I know it's there. Sorry
CWPASADENA 12-03-2014 11:59 PM
Re: transmission
I have used both a 39 and a Mitchell,
I like the Mitchell.
JMO,
Chris W.
Purdy Swoft 12-04-2014 11:34 AM
Re: transmission
Search threads by Dusty. Thats the guy with the cool green fenders. He did a neat job installing a 39 transmission in his model A coupe .
FRANK PKNY 12-04-2014 11:48 AM
Re: transmission
2 Attachment(s)
Thanks Guys as I have the transmissions I'm thinking the Mitchel is nice but costly. I have a rebuilt engine of unknown origin (just purchased the A) the engine just does not feel right. very high degree of vibration. I plan to pull the transmission and check the flywheel also check the top bearing on the drive shaft and u joint. Compression is 100lbs with a high compression head. Has an FSI ignition. I have been playing around with the timing using a vacuum gauge and my ear. however I think the rough running is a static balance problem. May install the cut down flywheel clutch combo and the 39 top loader while it's apart the top drive shaft bearing. Never did a drive shaft bearing in an A will do some research first.
emf 12-04-2014 01:48 PM
Re: transmission
Nice car, Frank. I heard you went to the dark side like John and I did... I have a 39 transmission in my roadster and you are welcome to take a look see, if the weather permits. Call me....
Frank
FRANK PKNY 12-04-2014 02:30 PM
Re: transmission
Yep the new models came out I guess!! LOL Have a very good offer going on my T not firm yet but promising. Still have a few horse wedding jobs to go and will shut that down after Christmas. John and I had a good chuckle over the A thing, funny all three of us converted. I still love my T's. Will be in touch, Frank
