mechanical or electric fuel pump I've got a basically stock '39 flathead in my '36 coupe ( just 2 carbs with the back one blocked off) , don't intend on driving it REALLY long distances, and I'm wondering if I should stay with the mechanical pump or block it off and put a small electric one back by the tank. I do like the "servicabilty" of the mechanical one but don't like the "perceived" lack of reliability of them. Who has the best / nosy reliable mechanical ones now? Thanks!
Re: mechanical or electric fuel pump I have both on the car...never an issue.
Re: mechanical or electric fuel pump stay with the mechanical, use an electric fuel pump as a back up, if you do use an electric one just remember that most of them put out around 5 to 7 pounds pressure which is to high for the ford carbs, you will need a pressure regulator to go along with it
Re: mechanical or electric fuel pump Quote:
I think the best rebuilder is Then and Automotive. http://then-now-auto.com/fuel-pumps/ |
Re: mechanical or electric fuel pump I've been running on the first fuel pump I put on the A V8... (Ten years ago) Got that from a pile of used parts... And, there's a spare pump under the seat that came from an engine core...
I was originally going to run an electric with this engine (in a different car)... Don't think I'll bother with the electric. Karl |
Re: mechanical or electric fuel pump Thanks guys!
http://www.aircraftspruce.com/catalo...facetpumps.php The key phrase is FLOW THROUGH! The Facets do. Mine's been in service for over four years now. |
Re: mechanical or electric fuel pump Good info.Thanx Richard.
Re: mechanical or electric fuel pump With stock flathead, I consider an electric fuel pump to be a "Band-Aid" to get around solving real problems. I had one in my '51 because of perceived "vapor lock". It turned out to be a substandard (grounds, battery, etc.) electrical system. Once I got everything straightened out, I removed the electric pump and everything has been fine since then. (This was about 10 years ago.) All of this being said, I am in north central Minnesota where is only gets above 90 5 or 6 days a year. Things may be different in Arizona and similar locales.
Re: mechanical or electric fuel pump your right Richard, but where are the 6v ones?
Re: mechanical or electric fuel pump Great info, guys. Richard, I'm thinking the Facet 40171......3.5 - 2 psi would be best?
1. Run a higher pressure than needed 12 volt Facet at 6 volts? 2. Use some other brand of pump? Just make sure it will allow fuel to flow through it when it's not running. |
Re: mechanical or electric fuel pump Good to see someone's blaming Electrical for vapour lock .I run a Mechanical pump only ,but you should always carry a spare that's been on the car and tuned to suet the push rod then removed and stored in the car .Ted
Re: mechanical or electric fuel pump car quest sells a 6 volt electric pump got one on my 39 and 46 they work great just switch the power and ground wires around.ive put a couple dozen on differant cars as a back up.also nice when car hasnt been used for a whilecant recall ever having to regulate one.there also pretty quite.we always keep 2 in stock.work on a lot of old cars.primarally use them to save on starter and batt.cant recall one going bad.
Re: mechanical or electric fuel pump Never had any problems with mechanical fuel pumps. I put on a 6V Carter from Macs to prime the carb if she's been sitting a while. The first one, even on this minor duty, only lasted a couple of years. I got another to save having to re-plumb and out of curiousity as to whether the first was an aberation. Been on a year ...
Re: mechanical or electric fuel pump Not quite sure what your twin carb set up is, but if you set them up right it's possible to achieve a 5% saving in fuel over a single carb, plus your engine gets a bit peppier. If done right it's a win win situation.
Flathead Teds method is 'Gold Standard' that would be my preference, and very simple too. |
Re: mechanical or electric fuel pump Again, thanks for all the info guys, much appreciated!
