1950 Ford Custom VIN ID Engine ID help I have just picked up a 1950 Ford Custom two door.
Can any one help me with breaking the serial number on the nameplate HDKC154735? There is also a number stamped on the firewall (K1160331)???? . The engine is a 6 cylinder with 7HA6050-02 cast in the cylinder head. Where was it made? What body type? Color Code? Trim Code? Any help is appreciated! Thank You! Throwback |
Re: 1950 Ford Custom VIN ID Engine ID help Quote:
Re: 1950 Ford Custom VIN ID Engine ID help Thank You for the suggestion. I have already looked at it. It does not seem to decode.
Re: 1950 Ford Custom VIN ID Engine ID help 2 Attachment(s)
The HDKC154735 is probably H0KC154735. This decodes as:
H= 6 cylinder 0= 1950 KC= assembled in Kansas City 154735= the production number The cowl code you have is a partial code. You should have something like the example below: Example: DA C73 4 41 15L 102 DA= Dearborn C73= Custom Deluxe Fordor 4= Meadow Green 41= Custom Deluxe Mohair 15= Day of month L= Month of year 102= Schedule item number I can send you a better copy of the service letter by email. [email protected] |
