Need pic of 28-29 CURVED Panel in rear rumble area I am looking for a picture of an ORIGINAL Only, "curved rear panel" for 28-29 roadster with a rumble seat PLEASE..and thank you
Re: Need pic of 28-29 CURVED Panel in rear rumble area 3 Attachment(s)
Assuming you mean the inner panel as I'm pretty sure the outer panel is the same for either rumble seat or trunk. Here's a couple:
Re: Need pic of 28-29 CURVED Panel in rear rumble area What is the purpose of this panel ?
Re: Need pic of 28-29 CURVED Panel in rear rumble area Structure to hold the spare tire bracket and lower rear panel. It is curved because the lid rotates through the area. It also moves the rain water to holes for draining.
Re: Need pic of 28-29 CURVED Panel in rear rumble area I have always wondered if there are TWO styles of curved inner rumble seat panels for 28/29 cars with rumble seats in them. Sport coupes (and other coupes) have a 7 1/2" high outer panel below the trunk where the top edge of the inner panel attaches. Roadsters on the other hand, have a 9" high panel below the trunk. My question is: How could the same curved inner panel fit both? It doesn't seem like it to me. Does anyone have an answer.
Rusty Nelson |
Re: Need pic of 28-29 CURVED Panel in rear rumble area Quote:
1928 Roadster has the earlier of the two. It's also very noticeable when viewing the car from the bottom....easy to recognize. The ones in the photos above are the later style.... I guess there could be an early style, but I haven't found one yet. |
Re: Need pic of 28-29 CURVED Panel in rear rumble area Thank you Randy that is EXACTLY what i needed. Appreciate it greatly
Re: Need pic of 28-29 CURVED Panel in rear rumble area Mark,
Here is a photo of the earlier panel.... . http://i693.photobucket.com/albums/v...1/DSCN0850.jpg |
Re: Need pic of 28-29 CURVED Panel in rear rumble area D.J no pic?????
Re: Need pic of 28-29 CURVED Panel in rear rumble area Funny, I see a picture of a curved inner panel.
Rusty Nelson |
Re: Need pic of 28-29 CURVED Panel in rear rumble area Yep, I see the picture also, and I'm not good with computors.
Re: Need pic of 28-29 CURVED Panel in rear rumble area talking to Dudley, I didn't realize the ribs pictured are up
instead of recessed |
Re: Need pic of 28-29 CURVED Panel in rear rumble area MOT i noticed that also...Now I need to find that EARLY PAN and get one for my Sport Couple...Great shot DJ
Re: Need pic of 28-29 CURVED Panel in rear rumble area The curved inner panel with raised ribs is an oddity. Mark, it's been a long time since I saw your Sport Coupe, but I thought the original panel was still in place. Also, My March 1928 has a perfect early panel and the ribs are recessed.
Re: Need pic of 28-29 CURVED Panel in rear rumble area 1 Attachment(s)
Here is my Curved Panel for my E28 Sport Coupe (Jan 9th), Great shape and the Ribs are RECESSED. Thanks Doug! (excuse some of the distortion in the pic:o)
Re: Need pic of 28-29 CURVED Panel in rear rumble area I thought sport coupes, which had rumble seats, had the steel bracket riveted to the bottom center that was used to support the spare tire carrier. The curved panel in the picture above doesn't have the bracket and hole in it.
Rusty Nelson http://i201.photobucket.com/albums/a...psc3a54531.jpg http://i201.photobucket.com/albums/a...psdd264c3f.jpg |
Re: Need pic of 28-29 CURVED Panel in rear rumble area YES that is correct. Here is the answer to that from Doug, Keep in mind my Car/panel is a E28 Jan:
The support for the rear wheel carrier that was riveted to the curved inner pan was introduced in mid to late 1928 and had that part and the square hole in the pan. The wheel carrier upper bolt passed through the outer panel and the inner support and was secured with a nut and lock washer on the inside. Even more interesting the parts supplies state in their catalogs that the curved spare tire support is for 30-31... |
Re: Need pic of 28-29 CURVED Panel in rear rumble area msraron, how ironic, I am in the process of replacing the rumble panel in my 1929 Business coupe. We know that the business coupe never had a rumble seat from the factory and I am the third owner of the car, so I am pretty sure it was never replaced in it's life. Best guess is that on the assembly line, they ran out of trunk panels and installed a rumble panel, who knows. I picked up a very nice trunk panel at hershey. PM me if you would like my rumble panel. I am open to a reasonable offer.
Re: Need pic of 28-29 CURVED Panel in rear rumble area If the early 28's did have the steel piece riveted to the curved inner panel, how was the spare tire bracket supported? Was the trunk type vertical inside the outer panel bracket used? It doesn't seem like there would be enough room for it and if there was, how was the upper spare tire bracket bolt and nut installed. I have wondered about this for some time. I would sure like to see an original early sport coupe spare tire/curved panel in a car.
Rusty Nelson |
