The Ford Barn
-   -   Early Radiator Shell Lacing Source? (https://www.fordbarn.com/forum/showthread.php?t=151197)
Neil Wilson 10-04-2014 08:45 PM
1 Attachment(s)
I am looking for a source for the radiator shell lacing used on the early radiator shell. See attached picture. My guess is that the lacing would be the same as for a T. Anyone know?
I can't remember where I got the lacing shown in the attached picture (senior moment I guess).
pat in Santa Cruz 10-04-2014 11:43 PM
Re: Early Radiator Shell Lacing Source?
Restoration Supply has that type.
800
306 7008
J Franklin 10-04-2014 11:46 PM
I would bet you would be happy with the lacing for the T. It would be less expensive than from R.S.
Roadster62 10-05-2014 07:13 AM
I wonder if the T used different width lacing? Black painted steel shells had square holes, the plated ones were made of brass and had round holes. Bob
Neil Wilson 10-05-2014 08:25 AM
1 Attachment(s)
I found the attached in the Judging Standards (page 1.1).
I searched the Restoration Supply catalog and they have 1/2" or 5/8" wide flat x 1/8" thick flat (woven brown fiber with asphalt)
I searched the Lang's Old Car Parts and they have a flat shell lacing:
"Threads through the holes in the radiator shell and protects hood from being scratched."
I will call them to find out the width/thickness.
BRENT in 10-uh-C 10-05-2014 08:34 AM
Neil, I am pretty sure the Ts used 1/2" lacing, -which is incorrect for the A shell. To be totally correct, you need to make it yourself.
Mike V. Florida 10-06-2014 07:37 AM
How does one go about making such a thing? I really am interested and not just causing trouble.
Neil Wilson 10-06-2014 10:21 AM
Brent,
Do you have any suggestions on how to go about making the lacing?
I called Lang's Old Car Parts - their hood lacing is 3/8" wide and sells for $3.95 for a 5' piece. Or, it can be bought by the foot @ $.95/ft.
The replacement lacing on my shell was 5/8" wide. After several years of being installed, it is now about 9/16" wide. I believe it requires about 5' 6" (maybe less) to do the A shell.
The Restoration Supply Company sells 5/8" wide (flat 1/8" thick) lacing. It is $2.50/ft. (part CLO003)
If 9/16" wide lacing can not be made/found, then the 5/8" wide lacing seems the best for originally.
