The Ford Barn
-   -   Grease fitting under inspection plate (https://www.fordbarn.com/forum/showthread.php?t=150953)
ped58 10-01-2014 05:59 PM
2 Attachment(s)
I recently saw on you tube a model A owner explain where all the grease fittings were and the last one he did was the one under the inspection plate for the clutch. I didn't know there was one, I found it and it looked like it never was greased in a long time. I took the fitting out and the little bit of grease was like cement. I got it all cleaned up and tested it with shot of grease and it's good to go. Since it has not had any grease in it for a long time, how many pumps should I give it?..........thanks
CarlG 10-01-2014 06:13 PM
Re: Grease fitting under inspection plate
Not much. It's just there to lubricate the bearing carrier as it slides on the shaft. Too much and you will be slinging grease on your clutch plate.
J Franklin 10-01-2014 06:23 PM
If yours has an original style throwout bearing it is also greased by that fitting. A couple or three pumps is all it needs once in a while
Girl with wrench 10-01-2014 07:57 PM
I did not know about this one, either! Thanks for posting the nice clear pictures. Very helpful.
ped58 10-01-2014 08:31 PM
I'm glad it helped.
