The Ford Barn
-   -   36 Ford Pickup Dovetails (https://www.fordbarn.com/forum/showthread.php?t=149306)
CWells 09-11-2014 01:47 PM
How does one go about installing a female dovetail assembly in a 36 Ford pickup. I did some research and it appears that models prior to and after 36 hold the assembly in with rivets or screws. It appears the 36 is welded on the backside of the pillar and I cannot get at it.
I need a new assembly installed and not just the metal aligning pins.
Lawson Cox 09-11-2014 06:32 PM
Re: 36 Ford Pickup Dovetails
Remove the upholstery to gain access.
Karl Wescott 09-11-2014 06:47 PM
The 1935-later female dovetail socket was spotwelded into the door post and is rarely in poor condition. To service gently dislodge the dovetail jaws from the detents in the housing that hold them, then the jaws and springs will fall out. Install the new replacement parts.
Note that some 1937-38 had plastic jaws. These have a different shape than the metal ones and are available reproduction from vendors who care.
