Air Cleaner ID help 6 Attachment(s)
This came with other Ford parts, looks like an AC filter.
2 1/4" throat 9 1/2" high 7 3/4" body Lid measures 7 1/2 " across Anybody recognize it? I want to list it , but I have no ID. Thanks Roy |
Re: Air Cleaner ID help ROY .....................
I don't know what it is, but I don't think it is for any V8 FORD flathead. MIKE :) (mikeburch) |
Re: Air Cleaner ID help Any part numbers on bottom? That will let you know for sure. Ford numbers are 78a-9600 or 91a-9600 for similar looking air cleaners.
Re: Air Cleaner ID help Quote:
No numbers anywhere I can see. Probably had a decal originally. |
Re: Air Cleaner ID help Does it fir the throat of your 94's and 97's. If not it may be 40's era GM. Rod
Re: Air Cleaner ID help 1 Attachment(s)
Here is a photo of 91A-9600 (since replaced with 78-9600). For Ford, the part number is on the bottom.
Re: Air Cleaner ID help Reminds me of a GM in line 6 air cleaner.
Thanks for the photo. Helps eliminate that one. Mine is smaller diameter and a bit taller. Doesn't seem to match any Ford that I can find , I'm leaning towards inline GM . Thanks for the input Roy |
