The Ford Barn
-   -   Starter bendix not engaging (https://www.fordbarn.com/forum/showthread.php?t=148040)
FLA48 08-27-2014 10:26 AM
On a 48, 59AB engine, the starter bendix stopped engaging in the flywheel. We have tried several different starters and no luck. The teeth on the flywheel and starter bendix both look good.
This problem began slowly over a period of time. Any suggestions would help.
scooder 08-27-2014 12:34 PM
Re: Starter bendix not engaging
When you say won't engage, what is it doing? Is it just spinning away? Is it grinding? Is it trying to engage? Is it just going clunk, and jamming? Is it going clunk, and just stopping?
This will help diagnose the problem.
The ring gear on the flywheel, these have been known to move on the flywheel this can cause similar issues. I think some of the reproduction ones are too loose a fit, and don't stay put.
Martin.
FLA48 08-27-2014 03:34 PM
Problem solved.
Several years ago he changed the engine and converted the electrical system to 12 volts. When he installed the starter, he failed to install the small bracket at the front of the starter that secures it to the oil pan bolt.
Over the years, the torque from the starter bent/warped the lower face plate where the two main starter bolts attache to the oil pan by about 3/8 ths of an inch. The resulting shift caused the bendix to slowly move away from the flywheel and not be able to engage. Luckily, he has a spare oil pan and will install it on the car. I gave him a spare bracket I had so he can correct the starter instillation problem with his replacement oil pan.
Wow what a fiasco trying to figure that one out.
