Need linc V 12 info/input... Need to transport an engine. Anyone know the weight of a complete V12 Lincoln engine ?
And, anyone know if KR Wilson made an engine stand holder device for V12 block (I believe it would most properly be held from side..exh man)? |
Re: Need linc V 12 info/input... I'm pretty sure someone posted a pic of a V12 on a stand and it looked the V12 fixture was bolted onto the normal V8 mount. In other words they used an adaptor to mount the V12.
It was a recent post on bellhousing strength/breakage. Mart. |
Re: Need linc V 12 info/input... 1 Attachment(s)
I'm guessing around 700lbs. The KR Wilson adapter for the V12 is a plate that bolts to the V8 mount that is Long enough to reach the exhaust ports.Here is a picture of mine .
Re: Need linc V 12 info/input... Quote:
YOU are the man:) !! Thanks, much |
