The Ford Barn
-   -   Tod winfield/ weiand head (https://www.fordbarn.com/forum/showthread.php?t=146876)
modelAtony 08-13-2014 09:06 AM
Tod, would you consider having Bill Stipe do some dyno testing on a combustion chamber design PRIOR to making a new head. How do they know the winfield is the better of the two. and is it the best that can be built. THE POWERS TO BE WOULD LIKE TO KNOW. HAVE FUN modelAtony tony white Lafayette, LA all the best to your new engine.
Purdy Swoft 08-13-2014 11:00 AM
Re: Tod winfield/ weiand head
Does Bill have a dyno test site??? If so I would like to add it to my favorites list.
modelAtony 08-13-2014 01:40 PM
Purdy, I just got home and saw you asked about stipe info here tis. SPECIALTY MOTOR CAMS specialtymotorcams.com . modelAtony
hardtimes 08-13-2014 02:29 PM
Hey Purdy,
Now only does Bill build engines, but he has his own dyno to test them on...how cool is that :)!
Just wish that I could have had him build a B for me ! That man is a perfectionist, IMO ! Based on everything that I've purchased from him..like works of art :D ! Too bad, for us, that he is retiring:(, but I got my last order in in time !
Purdy Swoft 08-13-2014 09:40 PM
Thanks Tony. I'll put it on my favorites list
Purdy Swoft 08-13-2014 09:47 PM
Originally Posted by hardtimes (Post 927108)
Hey Purdy,
Hey Rick, I know that Bill is one of the best. I run cams that he ground in a couple of my engines. I didn't know that he showed dyno test results on his site . Hopefully his machine shop will remain in business after his retirement. If not, it will be a bad loss to the model A performance community !!!
hardtimes 08-14-2014 01:01 AM
Amen brother ! A better professional and genuinely nice member of our hobby will not pass this way again soon, IMO ! Better get your order in now, as he explained that he is winding down and filling orders already taken !
Not sure what is to become of his shop. Seem to remember something of him having a son ? Maybe follow in Bills footsteps,eh !
colin1928 08-14-2014 06:08 AM
Why these heads have been tested many times over the last 80+ years and the crows foot Winfield always wins
I have owner many different performance heads and tried many of them on the same engine with only the head changed
Winfield Red original iron was always made the best power
other heads I have tried include Winfield Yellow, Super Winfield ( dispite the name not as good as the orginals) Weiand, Cyclone, Thomas, Evans, Simonds
This my opinion but almost every racer or engine builder I have spoken with who has tried different heads agrees the crows foot iron Winfield No1
Tod 08-14-2014 07:17 AM
Colin,
I sent you a PM.
Tod
Purdy Swoft 08-14-2014 10:25 AM
My take on dyno testing the different heads would be to give an idea of what the actual horsepower increase would be. We've seen tests on other heads. Sure, the Winfield heads are good and have stated compression ratios and a great history in the past .
nickair 08-15-2014 01:05 AM
Yes, I'm with Purdy. The dyno testing would be nice to see hp as well as the torque numbers. I am looking forward to the new head/s.
BRENT in 10-uh-C 08-15-2014 05:53 AM
Well, this also begs the question; can the crows food designed be improved upon by twisting or plug location.
Bill has the capability to make just a flat plate on his CNC where he doesn't need to build/cast a complete head with water jackets just to test with. He also has the ability to grind a special camshaft that can compliment the chamber design of a new head. Personally I also think this would be money well spent to do some dyno work, even if it requires adding $50.00 to the price of each head and amortize it over 150-200 units. The only downside to this new head is it may drop the prices on some vintage / era aftermarket heads. I say go for it!
Purdy Swoft 08-15-2014 11:07 AM
Depending on price, I agree. I've seen a lot of good parts that were priced so high that the common man would say, just forget it. If the price is reasonably, more parts will sell and still make a profit, maybe more in the long run
Tod 08-15-2014 11:36 AM
Brent and Purdy, pricing is less an object than coming up with chamber designs and time to play with them. I can make various chamber designs with my casting system that will keep pricing down. Keep in mind that I am basically the one-stop-shop, having the capacity to model up designs, make patterns, make castings (iron or aluminum) and machine those castings. It would take much too long to explain what I can do and just how I would do it but I am used to doing things others do not do or cannot do because my 37 + years in the industry has brought me into contact with quite a bit of data that I can utilize to get where I need to be. But time is always the enemy.
The twisted chamber interests me.
Tod
flyin-t 08-15-2014 12:38 PM
Back in the late 90's Allan Wylie dyno'd 6 heads (on a Sun chassis dyno), the new Aluminum Winfield, Anderson, Weiand, Price, Brumfield and the a Model B head. Winfield out performed all of them developing 41% more hp, 18, over the the "B" head. The others made 30% more, give or take.
This was published in the January '98 secrets of speed.
hardtimes 08-15-2014 11:19 PM
Hey flyin-t,
Very interesting ! Do you know if pictures were published, showing the comb chambers shapes....that were tested ? if so, can you picture them here. For instance, was the 'new alum Winfield' the crows foot or the other one pictured here lately ?
Dodge 08-16-2014 02:46 AM
The new aluminum Winfield is not a crows foot. Some have ground the crows feet into
the head though and had a improvement. It must be an air flow thing.
Tod 08-16-2014 07:30 AM
I can make both as cast.
Tod
flyin-t 08-16-2014 11:05 AM
Originally Posted by hardtimes (Post 928527)
Hey flyin-t,
I'll scan the article this weekend and post it here.
Tod 08-16-2014 02:59 PM
The new Winfield pattern is underway. While machining model A and T heads today I finished some pattern CNC cutting and was able to install my head pattern fixturing along side of the next pattern I need to cut. I decided to fit the new Winfield pattern into the time frame of the pattern I have to make. It will probably be finished in a couple of weeks.
Tod
