fitting sill plate brackets to sub frame 28-9 model Hi folks ,haw are the sill plate brackets fitted to the sub frame of a 28-9 roadster pick up, I have a new sub frame ,so it has no holes to show where thay go.Hope someone can help. Cheers Gerry.
Re: fitting sill plate brackets to sub frame 28-9 model If you could post a picture or two of the area you are having questions about, that would help get some answers.
Rusty Nelson |
Re: fitting sill plate brackets to sub frame 28-9 model Hi.On the 28-9 roadster pickup there is a sill plate,becouse this is quite flimsy,
it has a bracket that fits onto the sub frame to make a stronger sill plate when stood on. This bracket is bent up to fit the contour of the sub frame,Iam not sure if this just sits there held on by the sill plate screws or it has separate bolts or rivets that conect to the sub frame. Hope this will help .Cheers Gerry. |
Re: fitting sill plate brackets to sub frame 28-9 model bump
Re: fitting sill plate brackets to sub frame 28-9 model If you post a photo of the area where you have a question help will be a lot faster . I have a 28 pickup and could take photos .
Re: fitting sill plate brackets to sub frame 28-9 model 5 Attachment(s)
Any of the brackets that I've seen have been spot welded to the sub frame, however there's usually holes there too, so they may have been riveted on in the earlier production runs. Being as the bracket is eventually totally out of sight, any other method of attachment you may want to use shouldn't matter as long as it's sturdy.
Here's some pictures of a cowl where the sub frame and the bracket have been cut through - should show you what you need to line things up. Also an underside view of an original sill panel which was wrapped under but not crimped to the lower outside edge of the sub frame. Main consideration here is to try to get the reveals on the cowl, the door sill and the rear panel to line up. |
Re: fitting sill plate brackets to sub frame 28-9 model Hi folks,many thanks for your help .This will be a great help.Iam sorry I couldn't send any photos as my camera was away.
Cheers Gerry. |
