The Ford Barn
-   -   Front spring body welt (https://www.fordbarn.com/forum/showthread.php?t=146321)
Zack 08-07-2014 07:34 AM
I'm slowly working on my 31 coupe, and after reading about installing the front leaf spring, I have a question. Les Andrews book says to glue a piece of body welt to the top leaf and then grease. All the posts I've read say no to this practice. Is there a reason why I shouldn't?
Thanks
Zack
Zack 08-09-2014 06:20 AM
Re: Front spring body welt
Any ideas?
BRENT in 10-uh-C 08-09-2014 06:35 AM
Yeah, it's called a 'not so good' idea. Model-Ts used leather, and this practice was continued on the EV8 cars, but it serves no useful purpose on a Model-A if the spring is installed correctly.
H. L. Chauvin 08-09-2014 02:53 PM
Hi Zack
FWIW:
A front & rear spring can be thought of similarly to a horizontal wood structural beam made up of stacked, flat, horizontal 2x6's, connected together with one bolt in the center of the beam & center of the span..
When a bouncing load is applied, only the "ends" of the stacked 2xs's slide horizontally in shear.
Similarly, if there were shear or horizontal sliding between leaves in the center of a spring, the center bolt would be sheared or cut, just like cutting a piece of wire with a pair of snips; hence, like in structural beams, there is no shear in the center of a beam.
The center spring bolt of the front & rear springs needs to be in a "fixed" position held firmly by the square hole in the cross member.
If this center spring bolt does "not" move, nor the part of the top spring leaf immediately adjacent to the bolt:
A. Why grease it?
B. Why pad it?
C. Just tighten it firmly with the "U" bolts & it will not move nor squeak.
Hope this helps.
1930artdeco 08-09-2014 03:22 PM
I would grease it lightly all around just for corrosion protection.
Mike
