upgrading a model B 4 cylinder engine Has anyone had any success with the high compression heads for sale?
Re: upgrading a model B 4 cylinder engine I run a Snyder's 5.5:1 A head on one of my engines. I had to plug a couple of water ways but that causes no drama. I've been disappointed with the engine but can't say it is the head. I've checked everything. My next move is to check that the valve timing is correct. My A engine fitted out exactly the same as the B is waaaay better.
Re: upgrading a model B 4 cylinder engine Quote:
Re: upgrading a model B 4 cylinder engine My A has a B engine with a Brumfield head. I think it's 6:1, but not sure... This car runs as strong as I can imagine with no hesitation at all. running a B carb also with a B distributor.
I have nothing to compare to, but just my expectations.. Frank |
Re: upgrading a model B 4 cylinder engine Thanks Purdy, I am aware of that difference and timed the ignition from the piston at TDC. I got TDC by using a piston stop, turning the engine over in each direction and splitting the difference so it aint that.
