Flat Head Oil Pan 1 Attachment(s)
Can anyone tell me what the value on a flathead oil pan that aluminum is? Its stamped 1932, so I assume it only the 60hp flathead.
I heard they had it 2 ways. One with a dip stick, one without, Is that true? |
Re: Flat Head Oil Pan 1 Attachment(s)
Here is another picture/...
Re: Flat Head Oil Pan It is a 1932, But the 60 hp. was not made until 1937. Don't know about the dip stick.
Re: Flat Head Oil Pan If it's aluminum I'd guess it's a late 32, the early 32 had the dip stick in the block, right hand side rear about 2in. above the pan rail. The 32 was only 60-65 HP. It's probably priceless. Walt
Re: Flat Head Oil Pan Quote:
All the info I have or have read state the '32 V8 was rated at 65 hp. :) |
Re: Flat Head Oil Pan 65 horsepower was the original rating. The pan in the photos is the last of three versions of the '32 aluminum oil pan. As for value, if there are no cracks or other major damage it could bring upwards of $500. If there is a crack (that dark area in the front on the left side [when on an engine block] looks suspect), few have successfully welded a used '32 aluminum pan in the part of the pan in direct contact with oil.
Re: Flat Head Oil Pan one sold at hershey awhile ago, brought $1000.00
Re: Flat Head Oil Pan I saw one sell at Carlisle, PA maybe 20 years ago. Could not believe the number of $100 bills that the buyer shelled out for that item.
Re: Flat Head Oil Pan I honestly didnt think they were even close to that in value. thank you for the info guys.
