The Ford Barn
-   -   425 potvin cam idle rpm (https://www.fordbarn.com/forum/showthread.php?t=143407)
4tford 07-02-2014 03:54 PM
425 potvin cam in the 304 cu in. What should the idle rpm be set at. Street engine. Thanks Bill
36fordguy 07-02-2014 04:02 PM
Re: 425 potvin cam idle rpm
I have a Howard M14 that is a radical cam and it idles at 950 to 1000 rpm. I had a fuel dragster with a Potvin 425 , on the can of nitro it would idle at about 1200
Pete 07-02-2014 05:06 PM
Wherever you prefer it.
It will idle at 600 but will have better off idle throttle response from
900 to 1200.
Walt Dupont--Me. 07-02-2014 06:41 PM
1000-1100 rpm, Idle good with 3 carbs, blocked power valves, 94's 52 jets. Walt
Kahuna 07-02-2014 07:31 PM
Before I had a lifter fail and destroy Pete's nice cam, I found the idle speed to be ideal @ 800 RPM with the timing advanced to 12 degrees initial and 24 all in. The throttle response was fantastic and I expect the new cam, after I send another core to Pete, to be the same.
