Side curtain rod sockets Does anyone know where I can get a couple of the plastic (?) inserts that go in the side curtain rod socket holes on a Phaeton. My Phaeton has two sizes smaller at front and larger at rear of each side curtain.
Re: Side curtain rod sockets gday Bluedog.
Your sockets don't sound right. There is only one socket at the rear of each door on a 29/29 , and it is part of and built into the door catch inside . There is just a ferruled hole in the top door skin for rod to go in and locate in catch. |
Re: Side curtain rod sockets Interesting! I have a 1930 and have two sockets in each door. I will check out some local ones and compare.
Re: Side curtain rod sockets Are you talking about the curtain rod hole in the top of the door or the two curtain sockets on the outside skin?
http://abarnyard.com/temp/40-b_deluxe/door_top-1.jpg http://abarnyard.com/temp/40-b_delux...ster-c1top.jpg |
