Plug for Super Winfield head Anybody know what plug a Super Winfield head would take on a 31 banger
Re: Plug for Super Winfield head Reds Headers, who sold me my Winfield head recommended NGK 7022 BPR6HS
I've fitted them, but not yet run the motor Good Luck, Keith |
Re: Plug for Super Winfield head Thank you very much!
Re: Plug for Super Winfield head early heads had 18mm plugs, later ones used 14mm. i would use a champion D-14 or D-16 for 18mm and probably a H-16 or 18 for the 14mm head. with the head off check the proper length of H series to use.
Re: Plug for Super Winfield head I have BPR7HS on mine
Re: Plug for Super Winfield head I run NGK B7HS and am more than happy with them. I previously ran the B6HS which is slighly hotter.
Re: Plug for Super Winfield head Thanks guys!
