The Ford Barn
-   -   Vinegar in the radiator... (https://www.fordbarn.com/forum/showthread.php?t=140532)
Franchise_24 05-25-2014 08:45 PM
I'm running vinegar in my radiator for general cleaning. How long do you recommend to keep it in and run it in the car before removing it? Thanks.
newshirt 05-25-2014 10:00 PM
Re: Vinegar in the radiator...
I think that depends on the condition of your motor and radiator. When I first tried it, I was a little timid and only kept it in for three days. Then next year I got braver and kept it for a week. Others report 30 days.
I've been doing it every year, usually for a week each time.
Each time I do it, I get root beer that stains the gravel beside my driveway. It takes 6 - 10 flushes with water before it comes out clear. Others report a single flush with water comes out clear. So I think it really depends on the condition of your system.
Tom Wesenberg 05-25-2014 10:05 PM
I left mine in for 30 days, but my engine block had a lot of rust.
BTW, I used an inspection camera to look inside the top and bottom radiator tanks, and it's nice and clean.
redmodelt 05-25-2014 10:09 PM
You could also try Evaporust or diluted molasses. If you are using vinigar I would suggest using a Baking Soda flush follow up.
Terry,NJ 05-26-2014 08:28 AM
I'm not putting vinegar into my radiator for longer than one startup and short trip anymore. The last time I put it in for a week and wound up with pinholes.
Terry
FL&WVMIKE 05-26-2014 09:54 AM
Terry
Terry .....................
The vineger did not cause your pinholes, you already had them. You just cleaned out the rust, that was blocking the pinholes.
MIKE :) (mikeburch)
Bill Cal. 05-26-2014 10:45 AM
How much vinegar do you put in the radiator? Bill
dave in australia 05-26-2014 11:06 AM
When I did mine, I put in 2 litres, about 1/2 a gallon, and then filled the rest with water. I ran it straight away to mix it all together, and left it in for 30 days or so. Then drain, fill with water, drive about a bit, then drain and refill again.
Tom Wesenberg 05-26-2014 11:40 AM
I used straight white vinegar, which is 5% acidic. I used 2 1/2 gallons and ran the car for 30 days. Note that this will take out the grease from the water pump, and make a big mess on the engine. I wonder how it would work without running the engine? I would nuetralize with baking soda as soon as you flush out the vinegar. Winter set in so quick and hard last fall, just as I drained the system of vinegar, and I didn't get a chance to nuetralize the block, so now I have rust again. I have EvapoRust in the block right now and will drain it in another day or two.
PSXPAK 05-26-2014 02:54 PM
I just did it the other day with bout 2.5 gallons of vinegar. the inside was filled with disgusting rust colored slime. almost like grease. i put it in ran it for an hour and flushed the hell out of it. the reason i did it was the temp guage wasn't functioning at all, I removed it altogether anyhow. seems to run cooler now not pushing water out the cap in 3rd anymore at least.
700rpm 05-26-2014 04:21 PM
Drain it some place that you don't care about staining. I drained mine at the curb last sumer and there is still a brown spot on the pavement.
