The Ford Barn
-   -   Tool found on garage wall (https://www.fordbarn.com/forum/showthread.php?t=140432)
corvette8n 05-24-2014 04:39 PM
1 Attachment(s)
I found this tool hanging on my Dad's garage wall can it be used for a valve job on a flathead?
1952henry 05-24-2014 04:56 PM
Re: Tool found on garage wall
Looks like.
19Fordy 05-24-2014 05:22 PM
Valve spring compressor is what it is.
HCO41 05-24-2014 05:49 PM
Not a rare tool. Not for flatheads. I have one like it that is used as valve spring compressor on overhead valve engines. Bet it's not an offshore knock off.
Howard
Andy 05-24-2014 06:03 PM
I use one simular with the 8BA valves in my flathead.
34PKUP 05-24-2014 06:31 PM
Howard
Not for flatheads ?
With the correct forked end I have used one like it to replace several valves.
Ronnie 05-24-2014 06:33 PM
Originally Posted by 34PKUP (Post 883002)
Not for flatheads ?
Correct and the ends can still be purchased.
R
HCO41 05-24-2014 07:24 PM
I stand corrected. I'll give it a try if needed.
Howard
V8 Bob 05-25-2014 08:14 AM
Not a rare tool. Not for flatheads. I have one like it that is used as valve spring compressor on overhead valve engines...
Works great on flatheads as well as overheads. :)
http://i20.photobucket.com/albums/b2...veremoval1.jpg
Mart 05-25-2014 08:57 AM
It's not specifically a flathead tool, but can still be used on flatheads.
I have one like that that I use for assembling the valves up before I put them in the engine. I then use the pickle fork to pull the guide down and slip the horseshoe clip in.
Mart.
Ronnie 05-25-2014 09:30 AM
1 Attachment(s)
If you had the correct ends on that tool you could then have the tool jaws on top of the retainer and not pushed in the spring under the retainer.Then the tool is a pleasure to use as designed.These are the jaws.
R
V8 Bob 05-25-2014 11:37 AM
Originally Posted by Ronnie (Post 883255)
If you had the correct ends on that tool you could then have the tool jaws on top of the retainer and not pushed in the spring under the retainer.Then the tool is a pleasure to use as designed.These are the jaws..R
I have the ends you pictured, but find it easier to grab the springs as shown, allowing more room to split and remove the valve locks. I don't save used springs, so damaging them is not important.
Mike51Merc 05-25-2014 07:23 PM
I've got a couple of those. They're made for big jobs whether overhead or flathead heads. As they say---- if the shoe fits, wear it.
