The Ford Barn
-   -   drake halogens in a 36? (https://www.fordbarn.com/forum/showthread.php?t=138807)
Tom Morookian 05-06-2014 07:58 AM
I've been blind for a long time but now Drake says they make a halogen conversion with reflectors that have the proper focal length for the halogen bulb.
Anybody tried these? I'd prefer not to be the $135 guinea pig.
https://www.bobdrake.com/ItemForm.as...1-fa3c46010bb1
41PICUP 05-06-2014 09:24 AM
Re: drake halogens in a 36?
I haven't installed mine yet, bought them while the shipping was free. Will post whwn I get them installed.
nor6304 05-06-2014 10:10 AM
I put them in my 36 & very happy with them Seem to be bright enough with the orginal lens
40cpe 05-06-2014 10:58 AM
I can't speak for a '36, but I have them in my '38 and they work well.
Matt in Alameda 05-06-2014 11:56 AM
Just remember that they draw huge current...35 Amps, I believe.....
Matt in Alameda
jrvariel48 05-06-2014 02:41 PM
I put them in my '35 and I love em'. I'm also running a Powergen.
Kube 05-06-2014 03:00 PM
Matt in Alameda
Matt has spoken well...
38 coupe 05-06-2014 09:20 PM
I think a better solution is to get a pair of 170-957H bulbs from lbcarco. These are 6V halogen bulbs with the correct base and focal length for your original reflectors. If you use these you do not loose your parking lights. With the Drake conversion you loose the parking lights.
gkgeiger 05-07-2014 06:22 AM
Will these fit a '39 Deluxe?
Kurt in NJ 05-07-2014 07:26 AM
they will fit any light with the 3 slotted hole "pre-focus" bulb
http://www.classicandvintagebulbs.com/page3.html
can get 6 and 12 V, some bulbs 8v too, Anthony has a booth at Hershey usually, he also sells led bulbs, I have his bulbs in the model A for 15 years, still same ones, brighter than seal beams and use less amps, I use stock generator in the A
Tom Morookian 05-08-2014 05:43 AM
I'm already 12 volts and running thru high amp relays.
Drake does not say if these are 6 or 12 volt or if it's optional?
What bulb are they using - I doubt h-4's have the right focal length.
Chris Nelson 05-08-2014 04:01 PM
I put them in my 36, but with the original lenses, they do not put a lot of light on the road. Adequate, but not what I thought they should have done. I'm sure the lenses are causing the problem by scattering the light. They are 12 volt and were fairly easy to install. I am using a Ron Francis Wireworks relay in my panel.
Topsterguy 05-08-2014 06:17 PM
I put the set in my 36 too, 12 volt, and they're "OK" but not " fantastic", I'm sure because the stock lense scatters the beam.
