The Ford Barn
-   -   Difference between 33 and 34 frame (https://www.fordbarn.com/forum/showthread.php?t=138162)
Uptown83 04-29-2014 09:30 AM
I was hoping someone could explain or post pictures on how to identify a 33 frame vs a 34. I know the front cross member is a bit different on early ones? I cant remember any more and I don't know where I read this info. I tried searching with no luck. Hopefully someone can fill me in.
Thanks
Chris 04-29-2014 10:49 AM
Re: Difference between 33 and 34 frame
Front crossmember, as well as the front crossmeber supports where the radiator bolts down to are different. 33's have inboard shocks on the front, 34's are outboard...meaing 33's have a hole for the shock shaft to stick through the frame where as 34's do not (but the inner X has that hole drilled on both years). rear shocks are inboard on both 33 and 34
DavidG 04-29-2014 12:55 PM
There were two different unique-to-'33 models front cross members. The first is quite rare and easily identified by the 12" spacing between the holes for the motor mounts. The second has 17" spacing between the holes for the motor mounts (like the '34 front cross member). Both versions have rear corners that end before reaching the frame side rails to provide clearance for the inside-mounted front shock absorbers. The rear corners of a '34 front cross member extend all the way on to the lower lips of the frame side rails and are riveted there.
donQ 04-29-2014 08:31 PM
I've found that the 34 frame has a triangular radiator mount located between the front frame rail and the crossmember. It is held in place with 6 rivets or bolts. The 33 is similar except that the inside corner of the radiator support triangle is cut off and it is held in with only 4 rivets or bolts.
donQ
JSeery 04-29-2014 08:31 PM
Could also check the VIN number stamped on the frame rails (if they are still readable).
Uptown83 04-29-2014 08:43 PM
1 Attachment(s)
I have one where the radiator mount is a different bracket.
Didnt even think to check the vin.... now I feel stupid:rolleyes:
Also going to be welding this back in. Someone cut it out
Uptown83 04-29-2014 08:52 PM
vin says its a 34
Pete/Ct. 04-30-2014 06:51 AM
You should probably re-rivet the front cross member in. Simple to do Big Flats Rivet Co can supply all that is needed to do a great job. I've done a couple and its no big deal. Big flats even supplies simple instructions. I prefer rivet to welding or bolts as that is the way Henry did it and I'm sure he had his reasons. Pete/Ct.
DavidG 04-30-2014 06:58 AM
The front cross member in your photo is a '34, consistent with your frame's VIN. Interestingly, the two pieces at the front where the radiator attaches are '33s.
