The Ford Barn
-   -   Wiring harness - LENGHTS (https://www.fordbarn.com/forum/showthread.php?t=136890)
shaefer 04-15-2014 09:30 AM
So I am on the verge of completely replacing the wiring in our '31 Cabriolet (with cowls).
I found a diagram with all of the wiring information (colors, etc) BUT no information on lengths.
While I could pull out all the wiring and measure and order, that would mean a couple of weeks (at best) without a car and, since the car is driven pretty much daily, that won't work...unless it's the only way.
Does anyone have information on what lengths of wire will be needed to complete an entire wiring harness?
I am not so traditional that all of the colors need to be factory original, but I obviously need enough to finish the job. Any links or diagrams you can share would be appreciated. Thanks in advance!
Jon 04-15-2014 09:34 AM
Re: Wiring harness - LENGHTS
Have you looked at buying a new harness? they are only $30-40 and cut to fit
CarlG 04-15-2014 09:42 AM
Sacramento Vintage Ford makes them up with the correct wires, colors, lengths, and terminations. It's a no-brainer, just let them do it for you.
Mike V. Florida 04-15-2014 10:10 AM
Easier and cheaper to get one already done as they have said.
shaefer 04-15-2014 10:20 AM
Do they just need Make Model Year? If so then this is DEFINITELY what I will do. I was going to get the wire from either them or Brattons.
Mike V. Florida 04-15-2014 10:22 AM
Year, one bulb or two
http://www.brattons.com/search.asp?s...=any&PT_ID=all
CarlG 04-15-2014 10:33 AM
Cowl lights or not, turn signals or not.
