The Ford Barn
-   -   pivoting windshield on Model A roadster (https://www.fordbarn.com/forum/showthread.php?t=13512)
daviscf 09-14-2010 10:31 AM
The windshield on my 31 A Deluxe roadster pivot won't lock. The wind blows it past the cowl seals. If I try to tighten the wing nuts all the way, the top won't go onto the top of the stancheons.
Any ideas of what's wrong?
Greybeard 09-14-2010 10:44 AM
Re: pivoting windshield on Model A roadster
I have the same problem, but was able to tighten the wing nuts enough to solve. A guy told me he put sandpaper between the moving parts & that solved it for him.
Before I got mine tight enough the wind blew the windshield through & it hit the steering wheel hard enough to crack it. This design was for 40mph not 75 (mine is NOT stock).
daviscf 09-14-2010 08:32 PM
Thanks 'Greybeard' for your reply. I felt kind of stupid asking the question, but see I'm not the only one to have had the problem. Sorry abouit the broken windshield.
I'll try the sandpaper - but it seems there must be a correct fix for this.
I see that some Model A Parts suppliers offer both a large and small cone for the stancheon. I wonder if one can insert an extra cone on each side. (?)
Thom IV 09-14-2010 09:42 PM
FWIW
I've experienced the same problem. First the passenger side, which I was able to tighten, by using a tap to improve the threads on the wing nut. It is still holding.
Now the driver's side is doing the same thing. Not sure if I have it tight enough. Will test it out first chance I get..
midgetracer 09-14-2010 11:43 PM
I have the same problem on both my 30 and 31 roadsters. I was hoping someone made a small bracket that would fit under the wind wing brackets on the bottom to keep it from going too far back. Not original but it should work.
28RPU 09-16-2010 09:51 AM
You are going too fast.........:D
Barry B./ Ma. 09-16-2010 10:46 AM
No problem with that on mine so far. The rubber gasket keeps it from tilting too far. Of course I don't drive it over 50 either.
Aerocraft 09-16-2010 06:23 PM
I have had a similar problem if I drive it to fast or I am driving into a headwind. Cleaning up the threads helped. It is worse when I open the windshield a bit to allow air in. I solved that with a small wooden block wedged between the windshield and body sheetmetal. Chuckle, but it works! Gar Williams
antiquepa 09-16-2010 07:08 PM
I have the same problem with my 31, some where on the ford barn I read where if u had the original cones, not the after market the window would stay open. I have been thinking on a solution for some time and I plan on making some kind of set up to hold the window open this winter when I put my car away, If I come up with an Idea that works and looks good I will surley post when that day come, if anyone else comes up with a solutuon or Idea please post for all us roadster guys,,,Thanks in advance!
Tom Wesenberg 09-16-2010 11:55 PM
My 28 Phaeton has the original cones and stays where I put it.
bluesman31 06-14-2016 06:44 PM
Resurrecting this old postt. I have the same issue. Anyone ever come up with a good solution?
