The Ford Barn
-   -   Motor mount question (https://www.fordbarn.com/forum/showthread.php?t=134394)
kressej 03-19-2014 01:23 AM
I've got a 31 Victoria, put in a Mitchell this winter. Also replaced the front and rear motor mounts. The front is the one in the Les Andrews book where you drill 2 holes in the cross member. Put Float-a-motors in the back and added the little rubber block gadget over the U-joint that sits on the cross member.
Good news: vibration has dropped dramatically. Bad news: when I go over a serious bump, the Mitchell hits the floor pan. There is about 3/4" of clearance between the Mitchell and the floor.
Do I - Plan A: add some washers to the front mount to drop the U-joint area; Plan B: remove the rubber block & bracket by the U-joint; Plan C: ignore it; or what's your Plan D??? Thanks folks.
Brentwood Bob 03-19-2014 04:16 AM
Re: Motor mount question
try the original rear mounts. Seems to me the rear float a motor mis aligned the rear of the motor.
I did this and went back to all original mounts.
This was on a huckster body with a closed car cowl.
Bob
jw hash 03-19-2014 10:21 PM
did you order your Mitchell for the Victoria?, they install them farther back in the shaft to clear the floor.
MikeK 03-19-2014 10:42 PM
I don't see the engine placement as the problem. The torque tube with your OD pivots at the rear U-joint as the differential goes up/down over bumps. Too much upward differential travel may be the problem. Do you have rear shocks, and are they adjusted properly? Do you have the correct rear spring? Does your car sit at stock height or is it low? Plan D: Avoid 'serious' bumps.
Jordan 03-19-2014 11:59 PM
sounds like you have either the wrong set up in your car, or a weak rear spring.
Tom Endy 03-20-2014 12:57 AM
When you ordered the overdrive, did you tell Sue Mitchell it was for a Victoria? They offer a special unit for the Victoria that sits 4.5 inches further forward than their standard model. They also machine the top rear corner off at an angle to provide more clearance.
If you have the special unit installed you can do two things to help the situation.
1. Replace the rear 8-leaf spring with a 10-leaf. It will provide a little more clearance.
2. Glue a strip of 1/4" inch thick rubber along the machined top corner of the overdrive unit. It will cushion the blow when you bottom out.
You can also remove the dropped floor pan, it comes out fairly easy and have it sectioned and welded. I have a Ryan overdrive in my Vic and that is what I had to do.
Tom Endy
