'28 ccpu door to post screws size I would appreciate any information regarding the size and head type of the door to post screws for '28 CCPU. The only ones that I could remove were incorrect - flat head with lockwasher for spacing. Farmer fix.
Re: '28 ccpu door to post screws size That should be correct.....also, check the size you have.
Re: '28 ccpu door to post screws size I believe the thread is 12/24 and they are 3/4 inch long. the lock washer is an inverted star washer that is con-caved to fit the screw head. Ed Saniewski
Re: '28 ccpu door to post screws size 1928 thtough june 1930 closed cab pickup used 12/24 X 3/4 flat head screws, lock washers and square nuts for the door hinge to post
