The Ford Barn
-   -   Does anyone know what carb this is? (https://www.fordbarn.com/forum/showthread.php?t=132321)
drumyn29 02-23-2014 08:50 PM
1 Attachment(s)
Does anyone know what carb this is? I want to get it rebuilt.
jmeckel 02-23-2014 08:53 PM
Re: Does anyone know what carb this is?
Looks like a Tillotson x to me.
Joe K 02-23-2014 09:39 PM
Yup. Tilly X. Rebuild parts are fully available.
Joe K
tbirdtbird 02-23-2014 09:40 PM
Yep, Tilly X. good carb. Do NOT overtighten the screws and bolts else it will warp. Most ppl tighten way too much.
If you are gonna do it yourself I recently posted a method to get the main jet out, which can be quite a challenge. search under my username
https://www.fordbarn.com/forum/showth...ghlight=method
JBill 02-23-2014 09:40 PM
Yes, it's a Tillotson Model X, and mounted with bolts with nuts because the threads in the upper flange have been stripped. I've got one like that.
drumyn29 02-23-2014 10:38 PM
The dilemma I have is that the threads for the gas line are deteriorated. Any suggestions?
tbirdtbird 02-23-2014 10:59 PM
In Moller's book he says this is an insurmountable issue. I sure don't have a workaround. Check ebay they come up all the time for 30-60 bucks, use yours for parts
johnbuckley 02-24-2014 05:15 AM
Two major problems with Tillotsons - 1) they warp and 2) the threads get stripped. Some warpage can be overcome by very careful fettling. Overcome stripped mouting threads at the manifold with nuts and bolts ( as your's already has), stripped threads at the drain plug can sometims be fixed with a helicoil insert but stripped threads at the gas inlet generally make it beyond encomical repair. ( you can bodge a get-you-home measure with PFTE tape or JB weld)
BillLee/Chandler, TX 02-24-2014 08:51 AM
Thread repair in the mounting lugs is surprisingly easy. See
http://www.cedarcreekas.org/TechTopics/SalvagedCarb.pdf
johnbuckley 02-24-2014 11:33 AM
IMHO with Tillotsons if the mounting threads are stripped it's better to use a nut and bolt rather drill even more metal away for a Helicoil insert. Zeniths are much tougher all round and I agree that Helicoiling Zenith mountings is a good option.
jm29henry 02-24-2014 11:38 AM
well gentlemen we seem like we all found something we all agree on . it is a tilly x !!!!!!
