The Ford Barn
-   -   Mercury or Lincoln Cigar Lighter Element? (https://www.fordbarn.com/forum/showthread.php?t=132027)
Rowdy 02-19-2014 11:47 PM
Is this cigar ligher element Mercury or Lincoln? It has the 7HA prefix. Thanks Rod
https://www.fordbarn.com/forum/pictur...ictureid=25755
https://www.fordbarn.com/forum/pictur...ictureid=25756
https://www.fordbarn.com/forum/pictur...ictureid=25757
bbrust 02-20-2014 07:34 AM
Re: Mercury or Lincoln Cigar Lighter Element?
The 7HA usually denotes a 6 cylinder. If I read the number correctly, 7HA-6507 is the number for a 48-51 intake valve. Bob
Bruce Lancaster 02-20-2014 11:51 AM
7HA-65?7 would be an engine part! I don't think your tag and your element are actually relatives...
Rowdy 02-20-2014 11:57 AM
Thanks guys. I had not really looked at the main body number, but thought the 7HA prefix was odd for a lighter element as that was not likely to change with the number of cyl's. Thought there might be an angle I was not aware of to figure out the years and makes it is correct for. Will put it in the stray odds and ends box for now. Thanks Rod
