The Ford Barn
-   -   Vacuum Wiper Motor Vacuum??? (https://www.fordbarn.com/forum/showthread.php?t=132010)
leo 02-19-2014 06:16 PM
My wiper motor does not work and it is probably the motor but here is my question. How do I know if I'm getting enough vacuum at the motor to run it?
Mitch//pa 02-19-2014 07:43 PM
Re: Vacuum Wiper Motor Vacuum???
other than using a vacuum gauge put your tongue on the end of the hose. if you hear it slurp your good. another test if it holds a small piece of cardboard without falling off
Charlville 02-20-2014 04:22 AM
I have a cheap syphon pump with a small bore hose that enables me to generate enough vac to test the motor if that helps?
