Re: 59A in a `32 chassis
Almost all old Ford steering boxes are close to the exhaust manifold. This is one of the causes of steering box leaks using thin gear oil. I have used molly grease in my steering boxes for 30 years. Molly grease has a fairly low melt or drop point and the heat from the exhaust manifold softens the grease. The molly is a super lubricant and reduces wear. I always adjust mine so the center point is slightly tight and in a few weeks it wears in and stays the same for years. I set my 39 over 30 years ago and after 125,000 miles there is still no play. G.M.
