The Ford Barn
-   -   Rear Brake Camshaft Lever ID... (https://www.fordbarn.com/forum/showthread.php?t=131133)
Steve Plucker 02-09-2014 09:46 PM
I have a small selection of Rear Brake Camshaft Levers, A-2235.
All the ones for the LEFT side are marked with a "L".
However there are some without any markings... I am guessing that these are for the Right side?
Did the Right levers have no markings to distinguish them from Right and Left?
Thanks.
Pluck
jw hash 02-10-2014 12:45 AM
Re: Rear Brake Camshaft Lever ID...
Pluck
all the A-2235 and A-2236 I have seen, none of them are marked left or right, at times I wish they were, if you are not paying attention when you are putting them together you can get them on the wrong side however the emergency brake arms on the rear backing plate are marked R or L . John
RHD 02-10-2014 01:41 AM
I have only seen Rear Brake Camshaft Levers, A-2235 with a 'L'. never ever seen a 'R', although I have heard they do exist.
Gary Karr 02-10-2014 11:28 AM
On my E-28 rear levers, one has an "L" and the other a "R."
Midwest Tin 02-10-2014 11:59 AM
3 Attachment(s)
Hi,
I two sets of 31 NOS rear brake camshaft levers. One set has R and L and the other has LH and R. Interesting
d.j. moordigian 02-10-2014 12:10 PM
Steve,
The ones I've looked at were marked.
If it's a good one...I'd use it....
jm29henry 02-10-2014 12:11 PM
This is really neat !!thanks for sharing this is a great note to put in your own reference book THANKS!!
marcshall 02-10-2014 04:23 PM
i put a set of them on my front brakes ,had to make bushings because the hole is bigger . works good more leverage
