Radial Tire Pressure I recently put 215/65R16 radial tires on my cabriolet. The tire pressure on the side of the tire reads "44 psi maximum". The car steers, drives and rides good at this tire pressure; however, I do not know if this is a good pressure or not for the weight of this car. What do you recommend????
Bill Lee/Virginia Peninsula |
Re: Radial Tire Pressure I run #30 in my radials.
Re: Radial Tire Pressure 32-35 would be sufficient
44 is max psi rated for that tire. At 44 it will ride hard and wear the center tread |
Re: Radial Tire Pressure 28-32 depending on ride and temperature
Re: Radial Tire Pressure Needed tire pressure is all about load on the tire / maximum load of tire.
so even for oldtimers you can weigh or determiine the loads on the tires . Front and rear probably different because of the weight division. I kept myself busy with tire pressure calculation, so if you give actual tire loads seperatly , or axle loads. And from tires maximum load and pressure needed for that ( here max44 is maximum pressure of P-tire/standard load so Pressure needed for maximum load / maxloadpressure/reference-pressure is most likely 35 psi/2.4bar) , I can calculate the lowest save pressure for the tires. Also a factor is speed , but I think that wont be above 160km/99m/h here :). Greatings from Holland Peter |
Re: Radial Tire Pressure Running a wide tire on a narrow rim will make the center of the tire wear more, so you might try lowering the pressure.
