The Ford Barn
-   -   Model C head on a Model A block (https://www.fordbarn.com/forum/showthread.php?t=129162)
Neil Mylar LakewoodCA 01-19-2014 05:10 PM
Does anyone have a Model C head on their Model A block?
I refering to the Model B head that has the 'C' on it.
What needs to be done to a Model C head to run it on a Model A block?
I heard that they may be a couple of water port holes that should be welded up?
What type of gasket is used?
Did you notice any increase in horse power?
Thanks, Neil
V4F 01-19-2014 05:18 PM
Re: Model C head on a Model A block
neil , I had one awhile back . seems it was like 5.2 or 5.4 compression . less than the police head . I got it in a trade & sold it ......... steve
Bob C 01-19-2014 06:31 PM
I think you need to install set screws or pipe plugs in the two steam holes in
the center of the head. Vince's has a little info on his site http://www.fordgarage.com/pages/ABcy...comparison.htm
Bob
H. L. Chauvin 01-19-2014 06:57 PM
Water pump modifications are required for a B head.
I was very fortunate to have an excellent professional vintage mechanic teacher years ago who proclaimed three (3) Cardinal Head Rules that one should:
1. Never exceed 55 foot pounds head bolt torque ........ even with a Police Heads; &,
2. Never remove engine heads while engine is hot or even warm; &,
3. Always loosen & tighten head bolts gradually in proper sequence.
Hence always kept flat heads dead flat.
Never did anything to extra B holes in B heads or B engines, or B heads on A engines, or holes in B head gaskets, because I always had dead flat A heads on dead flat B engines, and/or dead flat B heads on dead flat A engines & used either an A or B head gasket, (whichever I had on hand), on any combination.
Always applied No, 2 Permatex non-hardening gasket sealer back then prior to modern silicone head gaskets.
Hope this helps.
DougVieyra 01-20-2014 12:15 AM
I had to paint my car Washington Blue to get the '32 'C' head to fit properly. It cost a lot - but the new 'C' head sure makes my car look a lot better !
Charlie Stephens 01-20-2014 01:08 PM
Hope this helps.
What water pump modifications are required for a B head other than using a B water pump on the 1932 head and a standard A pump on the police head?
Charlie Stephens
Jim Brierley 01-20-2014 02:12 PM
no! A head on B block yes.
Charlie Stephens 01-20-2014 02:13 PM
Thanks, Neil
Neil,
The problem with the the water holes goes away when you use the 1932-34 gasket with the 1932-34 head. The problem occurs when you run a 1932-34 block and a Model A head. The holes are too close to the edge of the gasket and will leak coolant into the combustion area.
Charlie Stephens
Logan 01-20-2014 03:39 PM
They're only like a 4.7 compression ratio. Very slightly higher than a stock A.
Neil Mylar LakewoodCA 01-20-2014 09:41 PM
Hi Charlie,
I'm confused.
If I use a Model B head (C on it) and a Model B gasket on my Model A block, wouldn't the water holes on the B head line up with the water holes on ther B gasket and then allow the water onto the A block? Did you mean to say use a Model A gasket?
H. L. Chauvin 01-21-2014 01:54 AM
Hi Neil,
A. While not being fully informed about all of the different Model A Religions, again per reply #4, I've many times used:
1. A Model A "Police Head" marked "B", on a B engine with no leaks, in conjunction with either providing a Model A head gasket or a Model B head gasket, sealed with Permatex No. 2; and,
2. A Model A "Police Head" marked "B" on a Model A engine with no leaks, in conjunction with either providing a Model A head gasket or a Model B head gasket, sealed with Permatex No. 2; and,
3. A Model B head marked "C" on a Model A engine with no leaks, in conjunction with either providing a Model A head gasket or a Model B head gasket, sealed with Permatex No. 2.
B. A Model B head has (3) water pump mounting holes in lieu of the (4) water pump mounting holes provided in a Model A head; hence, a Model B head requires a Model B water pump with three (3) mounting holes & a Model B water pump gasket with (3) holes.
C. In my humble experiences, with both head & block maintained "dead flat", coupled with proper sequence tightening of head nuts, & always using vintage Model T era Permatex No 2 gasket sealer on all four (4) mating surfaces, I never experienced head or head gasket leaks around the two (2) extra small holes & never plugged these holes.
D. Furthermore, with either cooling system, whether Model A or Model B, coolant is circulating with such a low pressure type pump that it does not create much internal engine water pressure & very little water head pressure -- if circulating coolant did have the water head pressure of domestic water at one's hose bibb, one could remove a Model A radiator cap & observe radiator water flying over the neighbor's roof.
E. Just one guys multiple experiences.
Neil Mylar LakewoodCA 01-23-2014 02:13 AM
Thank you everyone.
My plan is to install new head studs, a Model B head with the 'C' on it, with the 3 hole Model B water pump. I intend to use one of the new silicone head gaskets.
chiliman 01-23-2014 08:54 PM
Neil I run the C head on my A block just used a B gasket no problems rember you will need two front head bolts replaced with short ones good luck and have a blessed day
