Internal Rear View Mirror Mount 1 Attachment(s)
Hi All
In the photo is what my internal rear view mirror is mounted on. Not sure if this is a standard item, if so does anyone know what thread the bolts might be please? The mirror was held on with incorrect screws. Thanks Kevin |
Re: Internal Rear View Mirror Mount Not sure what is correct as my car is not a show car. Mine is screwed into the header with wood screws
Re: Internal Rear View Mirror Mount I am pretty sure the screws are 10-32 oval head nickel plated (if you want them to be as Ford did it). I believe they are 3/4" long. I installed the mirror bracket in my 28 coupe about 1 1/2 years ago and I am 99% sure what I wrote above is correct. I would advise you to carefully run a tap though the 3 holes to clean them out.
Rusty Nelson |
Re: Internal Rear View Mirror Mount Thanks guys.
