The Ford Barn
-   -   1932 Tudor wheel wells (https://www.fordbarn.com/forum/showthread.php?t=128821)
st6364 01-16-2014 01:59 AM
Hi, can I use roadster/coupe wheel wells to fix my rusty Tudor wheel wells?. Thanks
DICK SPADARO 01-16-2014 09:52 AM
Re: 1932 Tudor wheel wells
Yes and No, They are not the correct design first of all. Some guys use them to get extra clearance for tires with their hot rods so they work well for that but in doing so create an issue with the stock rear seat springs because it reduces the inner space distance between well panels.
st6364 01-16-2014 07:09 PM
Hi Dick, thanks for your reply. I was thinking of using them to create more room for wheels and tires. I have heard that I would need to modify my seat base, but I was thinking of using a different rear seat anyway. I thought using the roadster/coupe ones would be easier and look better than making something from scratch. Can you recommend a supplier?.
DICK SPADARO 01-17-2014 09:16 AM
Well you might try dickspadaro.com
DavidG 01-17-2014 01:57 PM
A most reliable supplier to the hobby!
st6364 01-17-2014 06:26 PM
Thanks for the response, I have sent you an email
st6364 01-24-2014 03:29 AM
Hi Dick, did you get my PM and email?
jim1932 01-25-2014 10:08 PM
Dick is easier to get with phone calls (during the business hours). His number is on the website. WWW.dickspadaro.com
st6364 01-25-2014 11:28 PM
I will try calling soon but would prefer email as I live in Australia and taking into consideration time differences it's hard to get a time to call.
jim1932 01-26-2014 09:20 AM
Oh,my bad… didn't catch the international piece. Dick is Eastern Standard Time if that helps.
