right hand tail light mounting Living in Europe, 28/29 RH tail lights were a dealer option on Tudors. Question: suppose lower body rail mounting is correct (of which I am not sure given my early '29 from Denmark), how did the dealers install the RH bracket ?
Hope anyone can help on this (multiple) dimemma |
Re: right hand tail light mounting Are you speaking of Drum tail lights that mounted to the Body crossmember?
Re: right hand tail light mounting Yes, drum tail lights; do you know how the RH forged iron bracket was mounted to the cross member ? Since the RH side wasn't factory prepared.
Re: right hand tail light mounting The picture shown is from a 28 Tudor RHD, which I had the pleasure of restoring many years ago. Although not a very good picture, it shows the original mounting to the sub-frame.
Re: right hand tail light mounting PM gestuurd. (PM Send)
