The Ford Barn
-   -   PowerHouse vs. standard generator (https://www.fordbarn.com/forum/showthread.php?t=123664)
DougVieyra 11-19-2013 02:58 AM
The Powerhouse Generator on my late '28 Ford died. As I have a box full of the later style ('29-'32) generators, I just pulled the Powerhouse off and installed the later style generator. It has been running fine on the car for about twenty years now.
So, now, having finally caught up on some of life's pressing demands, I am now ready to revisit the generator 'issue' on my '28. I see that none of the parts houses offer rebuilt Powerhouse generators. I presume that there is a valid issue which does not allow for easy rebuilding, but I know that it can be done.
My question is : ( ignoring what is 'proper' and 'fine point' correct ) is the later generator a better generator ? Did Henry Ford replace the Powerhouse generator with a better generator ? From a reliability and maintenance stand point, is the later generator a better generator ?
If there are Ford Barners who rebuild Model A generators I would like to get their input about the pros and cons of each type.
I would like to get feed back from users who drive and have driven their cars for years with both types of generators - enough to get a good assessment of the two generators. Before I go through the hassle and trouble of repairing my old Powerhouse generator, I would like to know that it has enough superiority over the later generator to justify the hassle.
Mike V. Florida 11-19-2013 03:48 AM
Re: PowerHouse vs. standard generator
Fordbarner Tom Wesenberg rebuilds them so you can eliminate the "hassle".
Both work find and both will last for many many years. The powerhouse, so called by how they look, does put out more then the "standard" unit, but Tom will be here soon to expand on this for you.
Steve Plucker 11-19-2013 06:25 AM
I second that...Tom W. is the GURU of Model A/AA Ford generator/starter rebuilding!
Pluck
al's28/33 11-19-2013 08:34 AM
Yes Thomas is the man to discuss this with. He has rebuilt two for me already Doug and will be working on a third Powerhouse soon. He also has devised a modern voltage regulator that replaces the adjustable brush to give more reliability. I seriously recommend you might send him yours and I'm sure he can bring it back to life!
Willie Krash 11-19-2013 10:43 AM
I have owned a generator/alternator shop for 35 years. I agree send it to Tom.
You can't beat hands on experience.
Purdy Swoft 11-19-2013 11:13 AM
The powerhouse generator will charge a few more amps than the tube type generator but is far more complicated.
Tom Wesenberg 11-19-2013 12:06 PM
Thanks guys! I prefer the powerhouse since it has a little more output, larger ball bearings in a large grease pocket, and is easier to work on. The brush holder is the fragile part and it is not reproduced.
ALWAYS save your worn out brushes because the wire and terminal on them can be used to make a new brush. You can buy the larger later brushes and cut and file them to size, then carefully drill a small hole for the wire and use a small brass screw to hold the wire in place.
I like to stay period correct and both generators are good units. Powerhouse is correct up through mid 1929, the long generator with 2 ball bearings is correct for 1929 through early 1930, then the rear bushing generator is correct for the rest of production. See the J/S for more specific dates and pictures.
BTW, I believe the change to the long generator was to save money.
youngs1 07-21-2014 04:24 PM
Tom, I have a side cutout Powerhouse that is original except brushes as far as I can tell. The belt tension arm to the timing cover had been missing from my car. I located the timing cover bolt at Hershey and installed both. Soon after, my generator spiked twice and went dead on the ammeter. Am I looking at a full rebuild? What does the surgery cost these days? Thanks!
Tom Wesenberg 07-21-2014 05:06 PM
The tension arm really isn't needed and that's why Ford dropped it in late 28. Hard to say what went wrong with the generator (or cutout). With the engine running, use a wire to jump across the two cutout terminals. If it now charges, then the cutout is bad. If it still doesn't charge, then the generator is bad.
Have you tried the "SEARCH" feature to read about powerhouse generators? I know I've said enough so you can overhaul it yourself, if you want to. Otherwise you can remove the rear cover and post pictures, so maybe we can spot the problem. It might even just be worn brushes.
