Worded a different way What has been done to a engine where you have to use a spacer for the two bolt dist mounting.the timing cover is for two bolt dist but dist snout is to long.This is in a 39 sedan not mine but a guy asking for help sence the snout was broken off the dist.I think the spacer was homemade because the mounting bolts went thru the spacer into timing cover to hold the whole thing togeather .I saw the correct spacer on Speedway book.
Re: Worded a different way He put a 2 bolt dist which has a long snout into a engine which has a longer cam shaft. 39 engines have a helmet dist which has a short snout, mismatched parts. ken ct.
Re: Worded a different way Ken,I believe the helmet type dist have 3 bolt mounting,so has someone used a 2 bolt timing cover. ?????
Re: Worded a different way Quote:
Re: Worded a different way Thanks Walt,that's what I wanted to know,good info .
