The Ford Barn
-   -   Removing king pin from spindle (https://www.fordbarn.com/forum/showthread.php?t=121667)
Theo 10-29-2013 02:03 PM
Hey guys. broke my spindle the other day. Have everything taken apart, and its ready to come off, but I don't know how to get the kingpin out. Is there any specific way to do this?
Will N 10-29-2013 02:44 PM
Re: Removing king pin from spindle
There's a locking pin that goes through the axle that locks the kingpin in place. Drive that pin out, and you will be able to pull the kingpin out.
Theo 10-30-2013 04:49 PM
Thanks for the response. Im not seeing the pin, can you tell me where it is on the axle.
Mitch//pa 10-30-2013 04:59 PM
1 Attachment(s)
pin and lock bolt//steering stop on other side
1 Attachment(s)
loosen lock bolt and tap lock pin out with hammer or equivalent
ursus 10-30-2013 07:09 PM
Sometimes the kingpin will wear a step on the lower bushing end where it can hang up and make removal difficult. Watch for this if it doesn't want to slide out and before you resort to the bigg-azz hammer.
